1994 Buick Lesabre Remote Starter
djtrini
Member - Posts: 17
Posted: October 06, 2003 at 1:22 PM / IP Logged
Hi guys,
I installed a ungo remote starter/alarm in a 94 Lesabre. I do know the car is equipped with the "Passkey" system.
Everything works but I can only remote start the car with the key in the ignition.
I searched on here and found out I need to put a resistor on the passkey wire, I dont have a tester to test the wire.
Do any of you know what size of a resistor I will be needing to use?
Any help would be greatly appreciated.
auex
Platinum - Posts: 5,041
Posted: October 06, 2003 at 8:54 PM / IP Logged
For this you will need a meter. Also it is a little more then just placing a resistor inline.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
djtrini
Member - Posts: 17
Posted: October 07, 2003 at 6:52 AM / IP Logged
So when I do get a meter and the correct resistor, what do I need to do to get everything working properly?
defective
Silver - Posts: 642
Posted: October 07, 2003 at 10:53 AM / IP Logged
you should just get an immobiliser module, they can be bought at most install bays. also DJTRINI didn't mention that you will need another factory key to do this, there is a chip in the key that the ignition needs to sense to turn the ignition on. the DEI part number is 555U it is a simple three wire box that you hide in your dash. other than that it's pretty simple, it can be done without the module but it's a nightmare to get right, this box makes it idiot-proof.
Hope i helped,
defective
Silver - Posts: 642
Posted: October 07, 2003 at 11:38 AM / IP Logged
oops actually it is not this system, its called a VATS system, sorry for the misleading.
you need to use a relay, here is the setup
pin 86 - ignition output from remote start, must be isolated with a diode
pin 30 -vats computer side of non-white wire inside orange sleeve in ignition
pin 87a - ignition side of non-white wire in orange sleeve in ignition
pin 85 - ground
pin 87 - to the white wire in the orange sleeve, but through a resistor
the resistor has to match the same inpedance value as the key, so use a multimeter to test the resistor in the key, one lead on each side, dont use your fingers to hold the leads.  the resistor has to be within 10 ohms of the key value.
hope i helped,
djtrini
Member - Posts: 17
Posted: October 10, 2003 at 2:04 PM / IP Logged
How do I completly bypass the system??
djtrini
Member - Posts: 17
Posted: October 10, 2003 at 2:07 PM / IP Logged
oops sorry I meant how do you permanently bypass the system because my dad wants it done that way.
defective
Silver - Posts: 642
Posted: October 11, 2003 at 1:48 PM / IP Logged
Attach the white wire to the other wire with the resistor between them.... idiot proof
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
