wiring diagram for 2002 monte carlo
eb11_18
Posted: July 18, 2002 at 10:15 AM / IP Logged
I need a diagram or some help for everything, including a good spot to run the power cable off of the battery or the aux post. Also a good place to put the factory radio
get back @ me
-eb-
eb11_18
Posted: July 19, 2002 at 11:45 AM / IP Logged
If any one did some install work on a 00 - 02 monte carlo give me a reply
-eb-
trusdamanr
Copper - Posts: 116
Posted: July 19, 2002 at 5:28 PM / IP Logged
i did a install on a 2001 monte carlo power cable was ran down the same side of the battery(had to drill).  didnt have to put the factory radio anywhere except out of the car.... the whole dash panel has to come out...start with the screw in the fuse panel the two under the steering column and the one in the glove box. also you have to tap into the fuse box for a accessory for the radio... if you need anything else just post it out there.
eb11_18
Posted: July 27, 2002 at 5:21 AM / IP Logged
i got the wire harness for the radio and the red wire goes in the fuse box but where???
-eb-
chriswallace187
Gold - Posts: 1,661
Posted: September 10, 2002 at 10:30 PM / IP Logged
I usually run the red wire off of the cold side of the BCM fuse, as it's switched on in the ACC position. If you don't have that fuse on the car, test the other fuses and use the tap on one that's hot in ACC.  the best place for the factory radio is between the quarter panel and the trunk bracing.
C Renner's Auto Electronix
muaid_97
Posted: September 11, 2002 at 3:16 PM / IP Logged
  i need to run wire directry    from +battery to insid the car but i can not find
any hole to run the wire   for dodge  intrepid 97
chriswallace187
Gold - Posts: 1,661
Posted: September 11, 2002 at 3:26 PM / IP Logged
what kind of wire? for what component?
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
