2001 jeep grand cherokee
n4tec
Member - Posts: 10
Posted: October 23, 2003 at 3:21 PM / IP Logged
     I'm looking for alarm/remote start wiring diagram for a 2001 jeep grand cherokee. Any help is appreciated. Thanks
vaderfop
Copper - Posts: 95
Posted: October 23, 2003 at 5:53 PM / IP Logged
12volts red & pink/black    +   ignition harness
Starter yellow    +   ignition harness
Ignition dk. blue    +   ignition harness
Accessory RED / black    +   ignition harness
Second Accessory BLACK/ orange +   ignition harness
Power Lock orn/blk - orn/pur 5wi door lock switches
Power Unlock pnk/blk - pnk/pur 5wi door lockswitches
Parking Lights- dk. blue/pink      steering column
Trunk/Hatch Pin tan/black - BCM, above diagnostic plug
Tach Wire   The 4.7L motor has a separate coil for each cylinder. Go to any coil and use any wire that is NOT dk. GREEN/ orange. On the 4.0L motor use any of the tan/stripe wires at the coil pack, or go to one of the fuel injector and use the wire that is NOT dk. GREEN/ orange
Brake Wire WHITE/ tan    +   drivers kick panel
Remember check all your wires with a DMM!
vaderfop
Copper - Posts: 95
Posted: October 23, 2003 at 5:54 PM / IP Logged
you can also use a DEI part 455j to interface with dork locks, dome light and factory alarm arm/disarm
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
