2001 Dodge Stratus VSS locaiton
bjp2995
Posted: October 29, 2003 at 9:23 AM / IP Logged
I have a 2001 Dodge Stratus, the RT coupe.  It's actually built by Mitsubishi Motors.  I'm trying to install a navigation system, but I need to find the VSS lead.  I can't follow the Dodge diagrams, because they are all wrong, and I can't seem to find any for Mitsubishi.  I have the 3.0 liter V-6.  If anyone knows what color the wire is, or where I could find it, I'd greatly appreciate it!
securinu
Silver - Posts: 772
Posted: November 05, 2003 at 8:44 PM / IP Logged
VSS Wire =     Yellow/white   Pin-66 on PCM in front of battery
Joe O'Byrne
Owner / Installer
bjp2995
Posted: November 21, 2003 at 10:52 AM / IP Logged
Thanks for the info!
However, I still am having no luck.  I cannot find a yellow wire with a white stripe anywhere in the car.  Furthermore, I can't find the PCM exactly either.  I was told that Mitsubishi sometimes likes to put them in the cabin rather than the engine compartment, but I can't find it either way.  When I look in front of the battery, all I see is a conduit full of wires, and inside there I cannot find the correct one.
Lastly, I had read that the VSS wire entered the PCM after it came off the transmission control module (or maybe I have it backwards, i don't remember).  The problem is, I've got a manual transmission, so no TCM!  That makes me wonder if the VSS wire is different or something.  I'm just quite confused!
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
