door panel
Villa05
Member - Posts: 8
Posted: July 20, 2002 at 10:59 AM / IP Logged
can i remove a door panel on a standard 1990 ford thunderbird without a door panel removal tool? and if so, how do i remove it?
Platinum - Posts: 12,488
Posted: July 20, 2002 at 11:42 AM / IP Logged
If you have power windows, then all you need is a philips screw driver. If you have manual windows then you will need a window crank arm remover or a 90 degree pick so that you can pull out the gold clip that holds the arm to the window roll down mechanism.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
