97 Honda Odyssey Alarm Wiring
dmtopper
Posted: November 03, 2003 at 12:36 PM / IP Logged
I'm in need of alarm connections and/or wiring diagram for a 1997 Honda Odyssey van.
Thank you
Z32tt
Member - Posts: 17
Posted: November 03, 2003 at 11:14 PM / IP Logged
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|                    |   |                            |
|        ACCESSORY|yellow              |+  |ignition harness            |
|       POWER LOCK|BLACK/ white         |-  |4 pin gray plug above       |
|     POWER UNLOCK|orange              |-  |fusebox in blue tape        |
| PARKING LIGHTS +|RED / black           |   |fusebox or left st col *1   |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|blue                |-  |gray plug above f-box       |
|     DOOR TRIGGER|WHITE/ black         |-  |16 pin right of st col *1   |
|  TRUNK/HATCH PIN|ORANGE / green        |-  |left of st. column *1       |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|blue                |   |at distributor              |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|blue/red            |-  |rt st col at relay          |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|RED / blu - RED / yel   |A  |driver's door switch        |
|  RF WINDOW UP/DN|blu/yel - blue      |A  |driver's door switch        |
|  LR WINDOW UP/DN|grn/blu - green     |A  |driver's door switch        |
|  RR WINDOW UP/DN|yellow - yel/grn    |A  |driver's door switch        |
Notes:
*1 There is a stack of five plugs to the left of the steering column. The park light wire is located in the lowest plug on the top left corner, trunk pin is in one of the upper plugs. The door trigger is on the right side of the steering column in a 16 pin plug like the 95 Accord. Plug is mounted higher but unclips so you can access the harness more easily. Trunk trigger is in a green 18 pin plug above fusebox.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
