2003 Oldsmobile Alero wiring diagram
thepencil
Gold - Posts: 1,526
Posted: November 05, 2003 at 10:41 PM / IP Logged
Thanks in advance guys.
Be careful whose advice you buy, but be patient with those who supply it.2003 Oldsmobile Alero wiring diagram -- posted image.
NowYaKnow
Gold - Posts: 1,217
Posted: November 06, 2003 at 7:16 PM / IP Logged
Here's the basics..Same as a grand am if you've done one of those..Let me know if you need any other info.
Driver underdash. Harness going into firewall. (If there's two harnesses running parallel to each other they will be in the harness that is higher up)
Constant: Red (+)
Ignition: Pink (+)
Starter: Yellow (+)
Heat/AC: Orange (+)
Horn: Black (-)
Parking Lights: Brown (+)
Ignition Switch. Remove radio to access
Ignition 2: Dark Green
Passlock 2: Yellow and Black Wires
Driver Kick: Harness Coming In From Driver Door Boot
Trunk Release: BLACK/ White (-)
Lock/Unlock: White (-) (Negative pulse to lock, unlock needs a 1,500 ohm resistor)
Dome Sup: GREEN/ Black (-)
Door Trigger 1: GREEN/ Black (-)
Pass Kick: Harness Coming In From Driver Door Boot
Door Trigger 2: Light Blue (-)
Other
Tach: White @ Coil pack
Brake: L. Blue (+) @ Brake Switch
Friday, January 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
