2002 ford focus door locks
plywood
Member - Posts: 34
Posted: November 26, 2003 at 1:11 PM / IP Logged
I have installed a remote start in a 2002 ford focus. After finding the wires for the door locks and testing them, I hooked them up. However, once the car is started the factory keyless entry and the aftermarket do not work. I'm thinking that I'm going to have to go directly to the lock and unlock motors to overcome this problem. Here is a copy of the wire code I used.
Ford
Focus
2000-2002
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
GRAY/BLACK
IGNITION SWITCH HARNESS
Ignition #1:
GREEN/ YELLOW
IGNITION SWTICH HARNESS*
Ignition #2:
N/A
Ignition #3:
N/A
Accessory:
YELLOW
Brake Light:
GREEN/ RED (+)
AT SWITCH ABOVE PEDAL **
Tach Signal:
BLACK/ LT. GREEN
AT COIL MODULE
Parking Lights:
ORANGE / YELLOW (+)
AT LIGHT SWITCH
Headlights:
OEM Alarm Disarm:
BLUE/LIGHT GREEN
IN DRIVERS KICK PANEL
OEM Alarm Arm:
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* This Vehicle Is Equipped With Ford's Passive Anti-Theft System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. ** This Wire Is Only Active When The Ignition Is On.
Ford
Focus
2000-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
RED
Starter Kill:
GRAY/BLACK
Ignition +12 Volts:
GREEN/ YELLOW
Dome Lights/Superv:
OEM Horn:
Power Lock:
BLACK/ RED (-)
DRIVER'S KICK IN DOOR BOOT ***
Power Unlock:
BLACK / YELLOW (-)
Trunk Release:
BLACK / YELLOW (-)
AT TRUNK RELEASE SWITCH
Alarm Input Wire:
Any help would be greatly appericatied. Thank You
Matt
Chapioshzx3
Posted: January 27, 2004 at 12:37 PM / IP Logged
Hi do you know the color of the cable, of The OEM Alarm arm?
Chapiosh
rODRIGUE
Member - Posts: 7
Posted: January 28, 2004 at 9:56 PM / IP Logged
plug BLACK/ green and BLACK / YELLOW at the unlock off your kit, with two diode....
plywood
Member - Posts: 34
Posted: February 03, 2004 at 9:25 AM / IP Logged
I've got the problem fixed. Thanks for the input.  I got the wire were they go into the bcm dehind the glove box.
Matt
Always remember to test wires with a Digital Multimeter!
