+12v pin locations in 2003 Jeep harness
brett-fts
Posted: December 30, 2003 at 10:06 AM / IP Logged
Hi there.. not installing this radio, am repairing a CD fault on the bench, dont have the vehicle handy to meter out the power lines or check their color/location..
OEM Chrysler/Jeep radio out of a 2003 Jeep (TJ?) .. grey connector on rear of radio.. looks like its probably 2 grey connectors actually on the vehicle side of things, one 22 pin and one 10 pin.  just need the Constant and switched power leads so I can power this thing up..
Thanks,
Brett Fraser
Fraser Technical Services
Victoria, BC
pat231
Member - Posts: 9
Posted: December 30, 2003 at 12:21 PM / IP Logged
Premium or not?
pat231
Member - Posts: 9
Posted: December 30, 2003 at 12:25 PM / IP Logged
Seems to be the same wirring anyway.
The 10pin connector is for the cd changer and the 22pin for the speaker and power.
Pin1: 12volts (constant)
Pin 2: Ignition 12 volts input
Pin22: Ground
