2003 echo wireing diagram
tams.teacher
Posted: January 08, 2004 at 1:54 PM / IP Logged
Looking for the wireing diagram for a 2003 echo 2 door.  I have an alarm to install and door locks.
Steve
plywood
Member - Posts: 34
Posted: January 08, 2004 at 2:39 PM / IP Logged
Here you go.
Toyota
Echo
2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
Black (+)
Ignition switch harness
Ignition  #1:
BLACK / YELLOW (+)
Ignition #2:
BLACK/ Red (+)
Ignition  #3:
N/A
Accessory:
WHITE/ Blue (+)
Brake  Light:
GREEN / WHITE (+)
Brake pedal switch
Tach  Signal:
Black (AC)
Diagnostic plug*
Parking Lights:
Green (+)
Headlight switch
Headlights:
N/A
OEM Alarm  Disarm:
Disarms with unlock
OEM Alarm  Arm:
Arms with lock
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 *The diagnostic plug is located under the driver side of the dash.
Toyota
Echo
2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE/ Red & WHITE/ Blue (+)
Starter  Kill:
Black (+)
Ignition  +12 Volts:
BLACK / YELLOW (+)
Dome  Lights/Superv:
RED / White (-)
Top of fuse box
OEM Horn:
WHITE/ Red (-)
Steering column harness
Power  Lock:
BROWN / Yellow (-)
Passenger kick panel**
Power  Unlock:
GREEN/ Black (-)
Trunk  Release:
N/A
Alarm  Input Wire:
RED / White (-)
Top of fuse box
Matt
Always remember to test wires with a Digital Multimeter!
Monday, March 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
