2000 + eclipse amp remote wire
boosted180
Member - Posts: 10
Posted: January 14, 2004 at 4:57 PM / IP Logged
Can not find the stock remote amp control wire. For adding a sub with an amp.
What is the color and what should I do? Thanks again.
geepherder
Platinum - Posts: 3,668
Posted: January 14, 2004 at 9:31 PM / IP Logged
Does the plug look like this:
http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf
If the plug's pointed toward you, with the clip on top, the blue wire at the bottom, just to the left of center should give you what you need.
