2001 Acura TL w/Navigation Wiring Diagram
Excelerate
Posted: January 21, 2004 at 2:41 PM / IP Logged
I need the wiring schematic for a 2001 Acura TL w/ Navigation. I need it b/c I will be doing installation of an aftermarket alarm w/ remote starting system and also for a Panasonic DVD system w/ flip out screen. Thanks.
abright52
Copper - Posts: 137
Posted: January 21, 2004 at 5:30 PM / IP Logged
Excelerate
Posted: January 22, 2004 at 9:29 AM / IP Logged
that site doesnt seeem to be workin.. is it just temporarily unavailable or a bad link?
abright52
Copper - Posts: 137
Posted: January 22, 2004 at 2:50 PM / IP Logged
Works for me. I will just paste it in:
Acura 3.2 TL 1999-2003
Remote Starter Wiring Colors and Notes
Function: Vehicle Color
     Location
Start: BLACK/ WHITE
     IGNITION SWITCH HARNESS
Ignition #1: BLACK / YELLOW
     IGNITION SWITCH HARNESS*
Ignition #2: WHITE/ BLACK
Accessory: YELLOW
Brake Light: WHITE/ BLACK
     AT SWITCH ABOVE BRAKE PEDAL
Tach Signal: BLUE
     2-PIN WHITE PLUG ON PASS STRUT
Parking Lights: RED / BLACK
     5-PIN GREEN PLUG AT FUSE BOX DR. KICK
Headlights: BLUE/RED (-)
     STEERING COLUMN HARNESS
OEM Alarm Disarm: BLUE (-)
     LOCATED AT SECURITY MODULE **
OEM Alarm Arm: ARMS WITH LOCKS
Notes:
*This vehicle may be equipped with a transponder immobilizer system. Use Universal Alarm Bypass Module part # 2x402 x can be any number.
** The security module is located underneath the passenger seat.
Alarm and Keyless Entry Wiring Colors and Notes
     Location
Constant +12 Volts: WHITE
Starter Kill: BLACK/ WHITE
     IGNITION SWTICH HARNESS
Ignition +12 Volts: BLACK / YELLOW
Dome Lights/Superv: BLACK/ WHITE (-)
     4-PIN PLUG ON FUSE PANEL
OEM Horn: LT.GREEN/ BLUE(-)
Power Lock: BLACK/ BLUE (-)
     PASSENGER FUSE BOX ***
Power Unlock: ORANGE (-)
Trunk Release: BLUE/RED (+) OR WHITE/ RED (+)
     SEE NOTE BELOW**
Alarm Input Wire: BLACK/ WHITE (-)
Notes:
** Use Blue/Red on 1999 - 2002, use WHITE/ Red on 2003. The MUX module is located behind the glove box.
*** See Installation Note #203 - Negative Pulse Door Locks Diagram. Alternate Wires Are RED / Yellow (-) For Lock And RED / Blue (-) For Unlock Located
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
