2003 Mitsubishi Montero Sport
dxfl
Posted: February 01, 2004 at 6:13 PM / IP Logged
Hope someone can help. I can't locate the LOCK MOTOR,
UNLOCK MOTOR and DISARM DEFEAT wires. Diagram I have
does not indicate where these wires are.
Any ideas?
Thanks,
David
boomer_106
Silver - Posts: 710
Posted: February 02, 2004 at 6:29 PM / IP Logged
Mitsubishi
Montero Sport
2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK / YELLOW (+)
Ignition switch harness
Ignition  #1:
BLACK/ White (+)
Ignition switch harness*
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
Blue/Red (+)
Brake  Light:
Green (+)
Brake pedal switch
Tach  Signal:
White (AC)
Engine speed detection connector**
Parking Lights:
GREEN / WHITE (+)
Headlight switch
Headlights:
N/A
OEM Alarm  Disarm:
BLACK/ Red (-)
At ETACS ECU***
OEM Alarm  Arm:
Blue / YELLOW (-)
At ETACS ECU***
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 *This vehicle is equipped with a Transponder Anti-Theft Security System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. **The engine speed detection connector is a single pin blue connector near the brake master cylinder. ***The ETACS ECU is attached to the back of the fuse box.
Mitsubishi
Montero Sport
2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
White (+)
Starter  Kill:
BLACK / YELLOW (+)
Ignition  +12 Volts:
BLACK/ White (+)
Dome  Lights/Superv:
GREEN/ Red (-)
2 pin plug above the fuse box
OEM Horn:
GREEN/ Black (-)
Steering column harness
Power  Lock:
BLACK/ Red (-)
At the ETACS ECU***
Power  Unlock:
BLACK/ Blue (-)
At the ETACS ECU***
Trunk  Release:
N/A
Alarm  Input Wire:
GREEN/ Red (-)
Notes:
***The ETACS ECU is attached to the back of the fuse box. See Note #201 Negative Trigger Door Locks.
dxfl
Posted: February 02, 2004 at 8:23 PM / IP Logged
Thanks for replying. However, I am installing an add-on system to the factory wireless system (Hornet 700T). The
install manual states that the connection I make to LOCK MOTOR reverses the polarity when the "lock" button
on the factory transmitter is depressed. Same for UNLOCK MOTOR. The "Power Lock/Unlock" wires stated in this diagram does not behave in this fashion when I have the DM connected to it. So I assume that I have
the wrong wires. Maybe I am in over my head!
Thanks,
David
Teamrf
Gold - Posts: 1,031
Posted: February 03, 2004 at 4:45 PM / IP Logged
If all else fails...take the door panel off and go directly to the unlock motor and see what color the wire is there...then find it in the kick or where ever it is coming from.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
dxfl
Posted: February 07, 2004 at 12:27 PM / IP Logged
Thanks for the reply.
Will do as a last resort. Hate to dismatle my new vehicle so soon after getting it. I'm going to
try probing all the wire in the kick panel to see
if I can find the power motor wires. Does anyone
know if I will be able to see the polarity change
using my DM?
Thanks again,
David
