2003 dodge ram 1500, crimestopper rs-900v1
ramitn
Posted: February 29, 2004 at 11:01 PM / IP Logged
 lookin for diagram for 2003 dodge ram 1500 installing crimestopper rs-900v1 remote starter where can i get a 815 & 315 ohm resistor for the keyless entry. THANKS
cbag1
Copper - Posts: 59
Posted: March 02, 2004 at 10:41 AM / IP Logged
ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|pnk/blk & RED / wht   |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|blue     (16 awg)   |+  |ignition harness            |
|  SECOND IGNITION|red or RED / wht      |+  |ignition harness            |
|        ACCESSORY|green & orange      |+  |ignition harness            |
| SECOND ACCESSORY|blue & blk/wht *7   |+  |ignition harness            |
|       POWER LOCK|WHITE/ green *1      |-  |driver kick panel           |
|     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|tan/pnk or tan/blk  |   |driver kick panel           |
|     UNLOCK MOTOR|blue                |   |driver kick panel           |
|    DISARM DEFEAT|tan/white           |   |passenger kick panel        |
| PARKING LIGHTS +|BLACK / YELLOW        |   |relay under hood at pwr ctr |
| PARKING LIGHTS -|purple / YELLOW *2    |   |headlight switch            |
|       HEADLIGHTS|purple / YELLOW *2    |-  |headlight switch            |
|     DOOR TRIGGER|*3                  |-  |*3                          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  FCTRY ALARM ARM|lt GREEN/ orange *4  |-  |driver kick panel           |
|FCTRY ALRM DISARM|same wire           |   |                            |
| DISARM NO UNLOCK|same wire           |   |                            |
|       TACHOMETER|NOT GREEN/ orange *8 |   |ign coil, coil pac, injector|
|      SPEED SENSE|WHITE/ orange        |   |wht conn. 2, pin 27 @ PCM *5|
|       BRAKE WIRE|WHITE/ tan           |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
Notes:
NOTE: Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U.  *1 Lock requires a negative trigger thru a 820 ohm resistor. Unlock requires a negative trigger thru a 330 ohm resistor. MUST use relays.  *2 Parking lights require a negative trigger thru a 330 or 1.4K ohm resistor. Headlights require a negative trigger thru a 1.8K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch.  *3 The LF door trigger is tan, and the LR door is tan/orange or PURPLE / orange. These wires are in the driver kick panel. The RF door trigger is tan/red, and the RR door is tan / YELLOW. These wires are in the passenger kick panel. Use all wires and diode isolate each. See directfax document #1076 for wiring information.  *4 This will also do door locks. Arm/lock is negative trigger thru a 2K ohm resistor. Disarm/unlock is negative trigger thru a 480 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays.  *5 The PCM (Powertrain Control Module) is on the passenger side firewall.  *6 The amplifier is located behind the glove box.  *7 These wires may not be necessary for remote start.  *8 Diesel tach wire use gray/black in the black plug at the PCM.
goto radioshack and buy a combination of resistor.  Connect this resistor in series to get the total resistance.
goodluck
ramitn
Posted: March 02, 2004 at 8:34 PM / IP Logged
  thanks cbag1 BIG HELP.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
