89 Ford F-150 Alarm/Remote Start Wire Diagram
harlyneisenmann
Member - Posts: 43
Posted: March 06, 2004 at 7:41 PM / IP Logged
please help,
     does anyone have the wire diagram for a remote start + sec system for a 89 ford f150.if anyone can help that would be great.ty
kiteman
Copper - Posts: 98
Posted: March 06, 2004 at 7:51 PM / IP Logged
   What part or wires are you looking for?
harlyneisenmann
Member - Posts: 43
Posted: March 06, 2004 at 9:11 PM / IP Logged
I am looking for the wire diagram to install it, need to know the color and what it is to install it.
auex
Platinum - Posts: 5,041
Posted: March 06, 2004 at 10:40 PM / IP Logged
Do you need the vehicles wiring diagram or the alarm's wiring diagram?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Dbfordtech
Member - Posts: 28
Posted: March 06, 2004 at 11:22 PM / IP Logged
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
RED / LIGHT BLUE
IGNITION SWITCH HARNESS
Ignition  #1:
RED / LIGHT GREEN
Ignition #2:
GRAY / YELLOW (# AWG)
IGNITION SWITCH HARNESS *
Ignition  #3:
GRAY / YELLOW-2WIRES
Accessory:
BLACK/ LIGHT GREEN
Brake  Light:
RED / LIGHT GREEN
(+) AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
DARK GREEN/ YELLOW
AT COIL ('# - TAN / YELLOW)
Parking Lights:
BROWN
(+) AT LIGHT SWITCH
Headlights:
RED / YELLOW
(+) AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * See Note #127 - Ford Ignition Switch Connection Diagram.
Ford
Pickup F Series
1989-1991
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
YELLOW AND YELLOW
Starter  Kill:
RED / LIGHT BLUE
Ignition  +12 Volts:
RED / LIGHT GREEN
Dome  Lights/Superv:
BLACK/ LIGHT BLUE
(+) AT PIN SWITCH
OEM Horn:
YELLOW /GREEN (-) W/
CRUISE - DK BLUE (+) W/O-STEERING COL
Power  Lock:
BLACK/ ORANGE OR
PINK / YELLOW IN DRIVER'S KICK **
Power  Unlock:
PINK/LIGHT GREEN
DRIVER'S KICK PANEL **
Trunk  Release:
N/A
Alarm  Input Wire:
BLACK/ LIGHT BLUE
(+) AT PIN SWITCH
harlyneisenmann
Member - Posts: 43
Posted: March 07, 2004 at 12:34 AM / IP Logged
thanks i will try that
harlyneisenmann
Member - Posts: 43
Posted: March 07, 2004 at 12:46 AM / IP Logged
by the way were do you get all the info on this
harlyneisenmann
Member - Posts: 43
Posted: March 07, 2004 at 12:48 AM / IP Logged
none of those wires are there the colors dont match
Dbfordtech
Member - Posts: 28
Posted: March 07, 2004 at 1:28 AM / IP Logged
harlyneisenmann,
Sorry, Thats all I have. This web site has all that info, its a great site. The colours they list are the same as what I gave you.
You did want the truck wiring right?
harlyneisenmann
Member - Posts: 43
Posted: March 07, 2004 at 10:28 AM / IP Logged
yes i did can you tell me the site name please, thanks for your help
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
