04 Trailblazer remote start
Irnotslow
Member - Posts: 45
Posted: April 04, 2004 at 10:23 PM / IP Logged
I am installing a RS that is an add on type (design-tech # 20022). I wish to use the positive pulse on the drivers side unlock motor to power a reversing relay to give the RS its neg pulse to initatate the start sequece. Can any one help.  Also this unit ONLY starts no keyless or alarm.
irnotslow
Bnluis
Silver - Posts: 578
Posted: April 04, 2004 at 11:15 PM / IP Logged
wire arelay this way
PIN 86 to wire door lock  or unlock motor in car
pin 85  and 87 to ground
pin 30 to remote start input negative
pin 87a not used
good luck
  LOCK MOTOR|gray                |   |driver door module in door  |
|     UNLOCK MOTOR|tan                 |   |driver door module in door
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
Irnotslow
Member - Posts: 45
Posted: April 05, 2004 at 5:19 AM / IP Logged
I notice the 12 pin connector on the fuse block. when I unplug it the driver door motor is inop, also a small black wire pulses when ever the motor is locked or unlocked. I think am at the wrong wire.
You said tan for unlock and grey for lock...and the Mod is IN the door?? is there any other known location?? I know an 02 chevy it is in the driver kick panel.
Is this wireing also the same for a 03 sivlerado?
irnotslow
Bnluis
Silver - Posts: 578
Posted: April 05, 2004 at 8:42 PM / IP Logged
inside door both cars
Luis
Sound Waves
Irnotslow
Member - Posts: 45
Posted: April 05, 2004 at 10:12 PM / IP Logged
thanx bud,   now I know its gonig to be a Pain in my a**
irnotslow
