2000 Nissan Frontier 2.4L
Welcome Guest :)
dmitchell84
Member -
Posted: May 05, 2004 at 1:46 PM / IP Logged
I've got a 2000 Nissan Frontier King Cab 2.4L and I'm looking for the VSS Vehicle Speed Sensor wire in order to hook up a navigation system. Would anyone possibly be able to help me out?
rudbwoy69camaro
Silver -
Posted: May 06, 2004 at 1:01 AM / IP Logged
2000 Nissan Frontier | Item | Wire Color | Polarity | Wire Location |
| 12V | green | + | ignition harness |
| STARTER | BLACK / YELLOW | + | ignition harness |
| IGNITION | BLACK/ white | + | ignition harness |
| ACCESSORY | RED / yellow | + | ignition harness |
| SECOND ACCESSORY | none | | |
| TACHOMETER | pink/blue or black | | instrument cluster or ECM *2 |
| POWER LOCK | yellow *7 | - | *3 |
| POWER UNLOCK | yellow/red *7 | - | *3 |
| PARKING LIGHTS + | blue/red | | steering column |
| PARKING LIGHTS - | none | | |
| DOOR TRIGGER | RED / black *4 | - | *3 |
| HEADLIGHTS | red, RED / blk *5 | + | steering column |
| WIPERS | *6 | - | steering column |
| LF WINDOW UP/DN | blue - blu/blk | A | at drivers door switch |
| RF WINDOW UP/DN | blu/yel - blu/wht | A | at drivers door switch |
| LR WINDOW UP/DN | none | | |
| RR WINDOW UP/DN | none | | |
| TRUNK/HATCH PIN | none | | |
| HOOD PIN | BLACK/ pink | - | *3 |
| TRUNK/HATCH RELEASE | none | | |
| FACTORY ALARM ARM | arms with lock | | |
| FACTORY ALARM DISARM | disarms with unlock | | |
| HORN TRIGGER | lt grn/red or brown | - | steering column |
| BRAKE WIRE | BROWN / red | + | brake pedal switch |
| LOCK MOTOR | blue | | *3 |
| UNLOCK MOTOR | GREEN / WHITE | | *3 |
| DISARM DEFEAT | purple or blu/red *9 | | *3 |
| DISARM NO UNLOCK | *8 | | |
| DOME SUPERVISION | none | non | none |
| SPEED SENSE | dk. GREEN/ black | 2 | ECM *2 |
| SUN ROOF OPEN/CLOSE | none | non | none |
| SUN ROOF LIMIT | none | non | none |
| LF SPEAKER | none | non | none |
| RF SPEAKER | none | non | none |
| LR SPEAKER | none | non | none |
| RR SPEAKER | none | non | none |
| RADIO 12V | none | non | none |
| RADIO GROUND | none | non | none |
| RADIO SWITCH | none | non | none |
| RADIO ILLUMINATE | none | non | none |
| POWER ANTENNA | none | non | none |
| Notes: | *1 Not required for remote start. *2 The ECM is located below the heater box to the right of the accelerator pedal, behind trim panel. The tach is in the top row, 3rd pin left of center of the plug. The VSS is in the 2nd row from the top, 4th pin right of center. *3 Located at the Smart Entrance Control Unit above the hood release in the drivers kick panel. The door lock wires only meter when turn the key in either door key cylinder. *4 If equipped with factory dome light delay, use GREEN/ red(-) for the drivers door and GREEN/ black(-) for the passenger door. Diode isolate each wire. The RED / black may also be found in the drivers A pillar. *5 These wires are for the low beams. For the high beams use RED / green(+) and RED / white(+) at the same location. *6 Use WHITE/ blue for intermittent, WHITE/ red for low, and blue/white high. *7 Unlock requires a double pulse. On vehicles without the factory alarm, can also find lt. GREEN/ red for lock and brown for unlock. *8 A single pulse to the unlock wire will disarm the factory alarm without unlocking the doors. *9 It is purple on the 2 door models, and blue/red on the 4 door. |
dmitchell84
Member -
Posted: May 06, 2004 at 6:12 PM / IP Logged
How do I access the ECM? It seems impossible to get to...thanks
Sunday, May 3, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
