2004 Dodge Caravan Alarm/Remote Start Wiring
Xakasohx
Posted: May 12, 2004 at 3:38 PM / IP Logged
 Can anyone please send over the correct wiring guide for a Dodge Caravan? Need it ASAP!
Holla Back!!
Autoobsession
Copper - Posts: 119
Posted: May 12, 2004 at 7:33 PM / IP Logged
12volts lt. blue/red (10A)  +  ignition harness
Notes: This wire is rated at 10 amps only. If installing any system with high current outputs, go to the battery for 12v.
Starter yellow  +  ignition harness
Second Starter PURPLE / brown  -  ignition harness
Notes: The second starter wire is negative trigger thru a 180 ohm resistor. MUST use relay. Refer to directfax document #1083 for wiring information.
Ignition pink/white  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory not required for remote start
Second Accessory N/A
Keysense
Power Lock PURPLE / green  -  conn. 3, pin 21 @ BCM
Notes: Lock is negative trigger thru a 5.3K ohm resistor. Unlock is negative trigger thru a 2.0K ohm resistor. MUST use relays.
The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Power Unlock same wire as power lock
Lock Motor tan/white    conn. 2, pin 10 @ BCM
Notes: The BCM (Body Control Module) is in the driver kick panel near the parking brake. It has 5 plugs in it, one 6 pin plug and four 34 pin plugs.
Unlock Motor tan/lt. green    conn. 2, pin 28 @ BCM
Parking Lights+ DO NOT USE
Parking Lights- WHITE/ brown  -  headlight switch
Notes: The parking lights are negative trigger thru a 2.1K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch. See directfax document #1082 for wiring information.
Hazards WHITE/ blue  -  conn. 5, pin 1 @ BCM
Turn Signal(L)
Turn Signal(R)
Reverse Light WHITE/ lt. green  +  conn. 2, pin 9 @ BCM
Door Trigger   -  conn. 3 @ BCM
Notes: The driver door trigger is purple in pin 6, the passenger door is PURPLE / white in pin 7, the left sliding door is PURPLE / gray in pin 8, and the right sliding door is purple / YELLOW in pin 5. Use all four and diode isolate each. See directfax document #1076 for wiring information.
Dome Supervision use door trigger
Trunk/Hatch Pin PURPLE / orange  -  conn. 3, pin 29 @ BCM
Notes: A diode must be placed inline on this wire to avoid problems with the dome lights and parking lights.
Hood Pin PURPLE / lt. blue  -  conn. 3, pin 30 @ BCM
Trunk/Hatch Release PURPLE / tan  -  conn. 2, pin 6 @ BCM
Notes: The hatch release is negative trigger thru a 1.69K ohm resistor. MUST use relay.
Power Sliding Door PURPLE / blue  -  conn. 3, pin 1 @ BCM
Notes: Left power sliding door is negative trigger thru a 1.5K ohm resistor. Right power sliding door is negative trigger thru a 2.7K ohm resistor. MUST use relays.
Factory Alarm Arm PURPLE / lt. blue  -  conn. 3, pin 14 @ BCM
Notes: Arm is negative trigger thru a 1.5K ohm resistor, this will also lock the doors. Disarm is negative trigger thru a 9.1K ohm resistor, if use double pulse this will also unlock the doors. MUST use relays.
Factory Alarm Disarm same wire as alarm arm
Disarm No Unlock
Tachometer   ac  ignition coil pack
Notes: On the 2.4L use blue/green or blue/tan. On the 3.3L/3.8L use blue/green, blue/tan, or blue/orange.
Wait to start N/A
Brake Wire WHITE/ tan  +  brake pedal switch
Parking Brake
Horn Trigger GREEN/ purple  -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
2004 Dodge Caravan Alarm/Remote Start Wiring -- posted image.
Immobilizer Bypass Module:Required: YesType: Sentry KeyPart #: 555C or 555U
Notes: Only vehicles with gray keys have the immobilizer.
