2004 Toyota Tundra Alarm Wiring
4mysecurity
Member - Posts: 22
Posted: June 08, 2004 at 9:57 AM / IP Logged
Can somebody please supply a wiring table showing wire colors/locations for installing an alarm system in a 2004 Toyota Tundra? Thanks for your help!
jfk51502003
Copper - Posts: 221
Posted: June 10, 2004 at 5:03 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / TUNDRA / 2003 / Remote Start
[PRINT THIS PAGE]
12voltsWHITE/ red and white + ignition harness
StarterGREEN/ black or BLACK/ white + ignition harness
Second StarterN/A
IgnitionBLACK/ red + ignition harness
Second IgnitionBLACK / YELLOW + ignition harness
Third IgnitionN/A
Accessoryblue/red + ignition harness
Second AccessoryN/A
Keysense
Power LockWHITE/ green - driver kick, door harness
Notes: Meter these wires while turning the key in the driver door key cylinder.
Power Unlockblue/red - driver kick, door harness
Notes: Meter these wires while turning the key in the driver door key cylinder. Unlock requires a double pulse.
Can also use the passenger key cylinder wire for unlock, which only requires a single pulse. It is RED / yellow or RED / white in the passenger kick, door harness.
Lock Motorblue/white 5widriver kick, door harness
Unlock Motorblue / YELLOW to BLACK / YELLOW 5widriver kick, door harness
Parking Lights+green + driver kick panel
Parking Lights-RED / black - steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door TriggerWHITE/ blue - driver kick, door harness
Dome Supervisionuse door trigger
Trunk/Hatch PinN/A
Hood Pin
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Armarms with lock
Factory Alarm Disarmdisarms with unlock
Disarm No Unlock
Tachometerblack or blue/white ac instrument cluster, brn plug
Notes: It is black on the 6 cylinder models, and blue/white on the 8 cylinder models, at the instrument cluster.
On the 6 cylinder models the black wire is also found on the driver side of the motor at the diagnostic connector. On the 4.7L V8 can also use BLACK/ blue at coil 1 on the driver side.
Wait to startN/A
Brake WireGREEN / WHITE + brake pedal switch
Parking Brake
Horn TriggerGREEN/ red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
2004 Toyota Tundra Alarm Wiring -- posted image.
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
