acc wire on gmc pickup
popeye004
Copper - Posts: 97
Posted: June 21, 2004 at 8:44 PM / IP Logged
I was just to about install a stereo in a 2004 GMC pickup and I couldn't find the switched ACC wire. I found the ground, 12 volt positive and all the other wires but no ACC wire. Can anyone tell what I might of missed.
foltzy
Copper - Posts: 46
Posted: June 21, 2004 at 9:04 PM / IP Logged
You have no ACC wire on any GM vechicles 2000 or 2001 and newer, you will have to pull it from an ACC fuse, or the accessory wire from the ignition harness..
Good luck
popeye004
Copper - Posts: 97
Posted: June 21, 2004 at 10:24 PM / IP Logged
ok and if I want it from the fuse panel which one do I pick acc1 or acc3 I dont think there was a acc2?
