02 Chrysler Concorde
Reddman1313
Posted: July 14, 2004 at 12:12 AM / IP Logged
I'm Looking for a wiring chart for a alarm/remote start...
yo
Besprend
Member - Posts: 29
Posted: July 15, 2004 at 11:45 AM / IP Logged
Sup, Here it is for your convenience.
12v pink/blk * Starter yellow * Ignition dk. blue/white * 2nd Ignition GREEN/ red * Accessory blk/ornge * 2nd Acc blk/whte *
*power lock WHITE/ green (back of fuse box) * power unlock same wire ( make note that the power door locks is a one wire trigger. You will need to use a resistor 2.7k ohm resistor for locks and 620 ohms for unlock connected to two relays)
*Parking lights is - yellow at the headlight switch (Use 220 ohm resistor to ground parking lights. The resistance should do for both parking lights and headlights)
*Door trigger is yellow also (In a brown connector at the rear of the fuse box)
*Tachometer (one of the coils) at any coil use the one with the tan stripes.
Hey bud, I gave this information for my best knowledge and if somehow I am mistaken please use a digital meter and never use test lights for this car. It could damage your car computer.
besprend
