1995 Audi A6
lazerb
Posted: September 18, 2002 at 5:01 AM / IP Logged
I'm looking for the best way to add a keyless remote to a 1995 Audi A6 quattro with vacuum locks.  The vehicle database lists wiring for door lock and unlock, however I though I read once that adding relays to the vacuum control located under the rear seat was the prefered way to go.  Anyone with experience and wire colors would be appreciated.
Platinum - Posts: 12,488
Posted: September 18, 2002 at 5:31 AM / IP Logged
|       POWER LOCK|BROWN / gray          |-  |door boot                   |
|     POWER UNLOCK|BROWN / green *2      |-  |door boot                   |
May require two pulses to unlock on some models. Also there is a single wire in the driver's door harness that toggles from (+) to (-) that can be controlled by relays - does not have the 3.5 second requirement, but also will not arm or disarm factory security.
