2002 Mazda Protege VSS, Tach Wires
The Xone
Posted: August 17, 2004 at 11:46 AM / IP Logged
Mazda Protege 2002 wring driagram, vss cruise conrols,ect
mo12v
Posted: August 17, 2004 at 10:34 PM / IP Logged
VSS Wire: PASS SIDE CONSOLE IN FLOOR OF VEHICLE POSITION 58 OF ECM
VSS Wire Color: ORANGE AUTO    -   GREEN/ YELLOW MANUAL
VSS Pulse: AUTO 18000ppm        MANUAL 4000ppm
VSS Tach Wire: SAME 104 PIN CONNECTOR POSITION 48
Tach Signal Wire Color: PURPLE / WHITE
Brake Switch Positive: GREEN
Brake Switch Negative: GREEN/ YELLOW
MO
