04 silverado
bigblackhoe
Member - Posts: 32
Posted: August 22, 2004 at 10:47 PM / IP Logged
ok im gonna be installing an amp in my friends 04 silvy. hes gonna use the stock hu. where might i find the accessory wire to tap into for the amps remote turn on? or if not the accessory wire, where are some other good wires to tap into?(other than the antenna)
NowYaKnow
Gold - Posts: 1,217
Posted: August 23, 2004 at 5:58 AM / IP Logged
You can find the accessory wire at the steering column look for a thick brown or thick orange wire. Make sure to throw a fuse inline as close to the wire as possible. Good luck,
Mike
bigblackhoe
Member - Posts: 32
Posted: August 23, 2004 at 3:46 PM / IP Logged
how big of a fuse?
auex
Platinum - Posts: 5,041
Posted: August 23, 2004 at 10:56 PM / IP Logged
For turn on lead, 3 or 5 will work fine. Basically the smallest fuse you can find.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
