2002 Ford Escape Alarm/Remote Start Wiring
khal2baba
Member - Posts: 7
Posted: October 16, 2004 at 3:10 PM / IP Logged
Hi need a remote start and alarm combo wiring diagram for 2002 ford escap can anyone help me out
     thanks
    e-mail : khal2baba@yahoo.ca
mo12v
Posted: October 16, 2004 at 4:07 PM / IP Logged
This is what I have:
Constant 12 voltsRED / L BLUE *IGNITION SWITCH HARNESS
Ignition 12 voltsL GREEN/ VIOLETIGNITION SWITCH HARNESS
StarterTAN/L BLUEIGNITION SWITCH HARNESS
Dome LightL GREEN/ ORANGE (-)PIN 1 OF GEM MODULE **
Trunk Pin SwitchWHITE/ VIOLET (-)PIN 18 OF GEM MODULE **
Parking LampBROWN (+)CENTRAL JUNCTION MODULE IN DR. KICK
Power LockPINK/WHITE **AT GEM MODULE OR
Power UnlockUNDER CENTER CONSOLE ***
* RED / L BLUE At Ignition Switch Fused At 10 Amps. Connect High Current Devices Directly To Battery Or YELLOW Wire At Fuse Box Which Is Fused At 40 Amps. ** GEM Module Located Behind Center Of Dash At Floor Level. See Tech Notes! *** Single Wire Door Lock System. PINK/WHITE Wire Requires Chassis Ground To Unlock Doors And Chassis Ground Thru A 1000 Ohm Resistor To Lock Doors.
Single Wire Resistor Door Locks
Accessories
Window UpDriver\ WHT/BLK
Pass\ WHT/YEL
DriverR\ RED / BLK
PassR\ YEL/BLU @ MAIN SWITCH
Window DownDr/ RED Ps/ TAN/BLU
DrR/ YEL/BLK
PsR/ GRY/ORG
Ign Key WarnBLACK/ PINK (+)STEERING COLUMN HARNESS
Trunk ReleaseN/A
OEM HornYELLOW/L GREEN (-)AT STEERING COLUMN HARNESS
HeadlightsRED / WHITE (-)AT HEADLIGHT SWITCH
OEM Alarm Arm
OEM Alarm DisarmBLUE/GREEN (-)AT GEM BEHIND LOWER CENTER OF DASH
 Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalD GREEN/ VIOLETAT COIL PACK OR PCM UNDERHOOD *
Ignition #2N/A
Ignition #3N/A
AccessoryBLACK/ L GREENIGNITION SWITCH HARNESS
Neutral SafetyNONE GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightL GREEN (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightBLACK/ PINK (-)IN DRIVER KCIK PANEL
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
* Wire Can Be Found In PIN 26 Of PCM In 4 Cylinder Engine. Wire Can Be Found In PIN 52 Of PCM In V6 Engines.
Immobilizer Bypass D
MO
