VSS for a 1993 Infiniti J30
metaverse
Copper - Posts: 210
Posted: October 18, 2004 at 4:54 PM / IP Logged
Anybody ? Thanks in advance..stuck while installing a pioneer Navi Sys 910 (avic 80 DVD) Also if possible the reverse signal input.. Thanks again..
metaverse
Copper - Posts: 210
Posted: November 10, 2004 at 4:18 PM / IP Logged
Reverse gear signal input for J30 is located at Pin 20 on the Auto Trans ECU located at driver's kickpanel..right in the fusebox area in the car. It is a think red wire which shows 12 volts in reverse gear on the transmission.
metaverse
Copper - Posts: 210
Posted: November 12, 2004 at 10:51 PM / IP Logged
VSS is located on on the gauge console. yellow/blue cable on the white 8 pin connector..plugged in at a slight angle. You can use the other wire as well..black I believe..
