wiring diagram for alarm on 84 silverado
gardner
Posted: October 23, 2004 at 3:41 PM / IP Logged
need wiring diagram, and possibly tips for viper alarm install.
gardner
mo12v
Posted: October 23, 2004 at 6:36 PM / IP Logged
REMOTE START Not Recommended:
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightWHITE(-) AT PIN SWITCH
Trunk Pin SwitchN/A
Parking LampBROWN(+) AT LIGHT SWITCH
Power LockLIGHT BLUEDRIVER KICK PANEL
Power UnlockBLACK/ WHITEDRIVER KICK PANEL
Positive Pulse Door Lock
Accessories
Window UpD\ D BLU P\ D BLU/WHT @ MAIN SWITCH
Window DownR/ BRN S/ TAN
Ign Key WarnLIGHT GREEN(-) STEERING COLUMN HARNESS
Trunk ReleaseN/A
OEM HornBLACK(-) STEERING COLUMN HARNESS
HeadlightsYELLOW(+) AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalWHITE OR PURPLE / WHITEDISTRIBUTOR OR ENGINE CONTROL MODULE
Ignition #2ORANGEIGNITION SWITCH HARNESS (HEAT-A/C)
Ignition #3N/A
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyN/A
Brake LightWHITE(+) AT SWITCH ABOVE BRAKE PEDAL
Reverse LightLIGHT GREEN(+) SWITCH ON LOWER STEERING COLUMN
Rear Window DefrostN/A
Carburated Engine.
MO
