Suzuki Ignis Alarm Wiring Diagram
chino
Member - Posts: 9
Posted: October 28, 2004 at 4:40 PM / IP Logged
Hey ...anyone has this diagram ? or can refer me to any other Suzuki which would be similiar? never had an ignis to work on. thanks.needed asap plz !!!
Claude
Member - Posts: 7
Posted: November 03, 2004 at 12:34 PM / IP Logged
Hope this helps you info based on a 2002 model.
Power Supply:  Red wire located in a multiway connector in the fuse box.
Ignition wire:    Yelow wire with silver references located in the wiring harness  behind the sill cover drivers side.
Direction Indicators : Blue / YELLOW wire with silver references and to the GREEN/ red wire with silver references located in the wiring harness behind the sill cover drivers side.
Central door locking: Negative control signal to make the lock and unlock of the doors, it is necessary to cut the BROWN / WHITE wire with SILVER references located in the wiring harness coming out of the 14 way white connector plced in the upper part,under the dashboard drivers side. Then connect your lock and unlock wires from the alarm to either side.  Door and boot switch connect to BLACK/ RED wire located behind sill cover drivers side. Imobilisation Point:  Fuel Pump cut thePINK wire with silver reference located in the wiring harness coming out of the 6 way white connector,directly on the comming out of the Ignition key. STARTER wire: BLACK / YELLOW wire located in the wiring harness coming out of the 6 way white connector directly on the coming out the the ignition key.
Thursday, April 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
