2001 Jeep Grand Cherokee Alarm/Remote Start/Stereo Wiring
Welcome Guest :)
Sierra2700
Copper -
rudbwoy69camaro
Silver -
Posted: November 27, 2004 at 3:46 PM / IP Logged
2001 Jeep Grand Cherokee | Item | Wire Color | Polarity | Wire Location |
| 12V | red & pink/black | + | ignition harness |
| STARTER | yellow | + | ignition harness |
| IGNITION | dk. blue | + | ignition harness |
| ACCESSORY | RED / black | + | ignition harness |
| SECOND ACCESSORY | none | | |
| TACHOMETER | *6 | | *6 |
| POWER LOCK | orn/blk - orn/pur *7 | 5wi | door lock switches *1 |
| POWER UNLOCK | pnk/blk - pnk/pur *7 | 5wi | door lock switches *1 |
| PARKING LIGHTS + | use (-) lights | | |
| PARKING LIGHTS - | dk. blue/pink *2 | | steering column |
| DOOR TRIGGER | *4 | - | *4 |
| HEADLIGHTS | yellow | *3 | at the headlight switch |
| WIPERS | dk. GREEN/ red | - | steering column |
| LF WINDOW UP/DN | lt. blue - white | A | drivers door lock switch |
| RF WINDOW UP/DN | brown - purple | A | passengers door lock switch |
| LR WINDOW UP/DN | dk. blue - RED / wht | B | drivers kick panel |
| RR WINDOW UP/DN | gray - dk. green | B | passengers kick panel |
| TRUNK/HATCH PIN | tan/black | - | BCM, above diagnostic plug |
| HOOD PIN | none | | |
| TRUNK/HATCH RELEASE | none | | |
| FACTORY ALARM ARM | arms with lock *7 | | |
| FACTORY ALARM DISARM | lt. GREEN/ orange *7 | - | *5 |
| HORN TRIGGER | gray/orange | - | steering column |
| BRAKE WIRE | WHITE/ tan | + | drivers kick panel |
| LOCK MOTOR | ORANGE / black | | drivers door lock switch |
| UNLOCK MOTOR | pink/black | | drivers door lock switch |
| DISARM DEFEAT | pink/purple | | passenger kick panel |
| DISARM NO UNLOCK | none | | |
| DOME SUPERVISION | yellow/dk. green *7 | - | BCM, above diagnostic plug |
| SPEED SENSE | WHITE/ orange | | PCM, passenger side firewall |
| SUN ROOF OPEN/CLOSE | none | | |
| SUN ROOF LIMIT | none | | |
| LF SPEAKER | grn/orn - brn/red | | at the radio |
| RF SPEAKER | purple - blu/pnk | | at the radio |
| LR SPEAKER | wht/grn - grn/wht | | at the radio |
| RR SPEAKER | grn/wht - blu/orn | | at the radio |
| RADIO 12V | RED / white | | at the radio |
| RADIO GROUND | black | | at the radio |
| RADIO SWITCH | WHITE/ red | | at the radio |
| RADIO ILLUMINATE | none | | |
| POWER ANTENNA | none | | |
| Notes: | NOTE: Jeep vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U. *1 Use ORANGE / black and pink/black at the drivers door lock switch to lock and unlock the drivers door. Use ORANGE / purple and pink/purple at the passengers door lock switch to lock and unlock all of the other doors. *2 The dk. blue/pink will flash the hazard lights. They will flash even with a latch input to the wire. The parking lights can be activated by using a 1300 ohm resistor to ground on the yellow headlight wire. *3 Use a 330 ohm resistor to ground for headlight activation. Use 80 ohms to ground on the same wire to operate both the headlights and parking lights. *4 There are 4 separate door triggers wire, one for each door. Use all 4 wires and diode isolate each together. The drivers door is tan/red at the drivers door lock switch. The passenger door is tan/red at the passengers door lock switch. The drivers rear door is tan/orange and the passengers rear door is tan / YELLOW at the BCM. WHEN USING A 455J INTERFACE MODULE, IT IS NOT NECESSARY TO USE THE SEPARATE TRIGGER WIRES. USE THE YELLOW WIRE AT THE UNDERDASH LIGHT FOR DOOR TRIGGER. *5 Factory alarm disarm requires a 463 ohm resistor to ground on the lt.GREEN/ orange wire at the drivers door lock switch, you MUST use a relay. *6 The 4.7L motor has a separate coil for each cylinder. Go to any coil and use any wire that is NOT dk. GREEN/ orange. On the 4.0L motor use any of the tan/stripe wires at the coil pack, or go to one of the fuel injector and use the wire that is NOT dk. GREEN/ orange. *7 Can also use DEI part number 455J door lock interface control module. This will control door lock, unlock, arm, disarm, dome light supervision and more. |
Sunday, May 3, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
