2005 ford escape door lock issue
mps446
Member - Posts: 7
Posted: December 15, 2004 at 8:35 AM / IP Logged
Hello. I have a question. I am going to install a viper 560xv into a 2005 escape. the problem is that the person still wants to have the unlock feature of the oem remote which is unlock once, driver door only, unlock twice, all doors    can anyone help me out with this Thank You
KarTuneMan
Platinum - Posts: 7,056
Posted: December 19, 2004 at 3:32 PM / IP Logged
Does the vehicle have factory security???
In the drivers kick drivers door unlock is RED / orange reverse polarity
unlock and disarm is blue/lt green double neg pulse first will disarm second will unlock ALL
lock and arm whiote/purple neg pulse   I have never done this drivers door priority on this car so I cant help with "how" to wire it. The key is if the car has factory security
mps446
Member - Posts: 7
Posted: December 19, 2004 at 6:19 PM / IP Logged
Yes it has factory security
NowYaKnow
Gold - Posts: 1,217
Posted: December 19, 2004 at 7:17 PM / IP Logged
As long as the 560XV has a driver door priority output you'll be good to go.. Basically you find the driver door unlock motor wire and cut it. You'll need a relay and want to wire it like so:
85: To (-) driver door output from module
86: To (+) 12volts constant
30: To motor side of RED / orange motor wire
87: To (+) 12volts constant
87a: To switch side of RED / orange motor wire
Good luck,
Mike
