05 sequoia Techometer wire
doityourself
Posted: December 26, 2004 at 12:30 PM / IP Logged
Please Help and thanks in advance.   I am trying to locate the tachmometer  YELLOW /GREEN for couple week now because the vehicle won't start when it's cold,  what i was told hooking up this wires supposet to help start  in the cold weather.   here where several site told me..   I have a 2005 toyota sequoia.
Tachometer          YELLOW /GREEN          ac                ECM, 2nd plug from right. pin1
Tachometer          YELLOW /GREEN                              ECM, 28 pin plug in pin4  ECM.   The ECM is behind the glove box.
Tachometer          YELLOW /GREEN                              ECM, 32 pin plug in pin5 ECM.   You Can Also Use GREEN/ YELL At
        Switch above Petal.
Would someone please varify which one is correct or are they all correct.  Thanks, in advance.
doityourself
Posted: December 27, 2004 at 3:04 PM / IP Logged
Any help Please!!!!. Thanks,
