2005 Ford F-150 Alarm/Remote Start Wiring
ivanp
Posted: December 29, 2004 at 10:48 PM / IP Logged
May someone please post a wiring diagram for a 2005 Ford F150. It will be greatly appreciated.  Thanks!
Hello
auex
Platinum - Posts: 5,041
Posted: December 30, 2004 at 9:55 PM / IP Logged
05 Ford F150
12volts lt. GREEN/ purple (20A)   +   ignition harness
Starter RED / lt. blue   +   ignition harness
Ignition dk. blue/lt. green   +   ignition harness
Accessory BLACK/ lt. green   +   ignition harness
Keysense BLACK/ pink   +   ignition harness
Power Lock pink / YELLOW   -   DKP or BCM, green plug, pin 9
Notes: The BCM (Body Control Module) is on the driver side rear cabin wall.
Power Unlock pink/lt. green   -   DKP or BCM, green plug, pin 1
Parking Lights+ brown   +   switch or BCM, blue plug, pin 6
Door Trigger BLACK/ yel (L), BLACK/ pink (R)   -   DKP, gray plug, pins 22, 23
Notes: The wiring above is for vehicles without keyless entry. Vehicles with keyless entry, the door trigger wires are found at the BCM, green plug. The LF door trigger is BLACK / YELLOW in pin 4. The RF door trigger is BLACK/ pink in pin 5. The LR door trigger is BLACK/ lt. blue in pin 12. The RR door trigger is BLACK/ white in pin 13. Use all wires and diode isolate each.
Tachometer NOT RED / lt. green or red   ac   any ignition coil or fuel injector
Brake Wire lt. green   +   brake pedal switch
Parking Brake lt. GREEN/ red   -   parking brake switch
Horn Trigger dk. blue   -   switch or BCM, blue plug, pin 12
Immobilizer Bypass Module: Required: Yes Type: SecuriLock
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
ivanp
Posted: December 31, 2004 at 10:25 AM / IP Logged
Hello
michf150
Posted: January 09, 2005 at 2:33 PM / IP Logged
I am looking to install a remote keyless entry system into my 2005 f150 stx. I need to find a 12v and a negative to connect this set up too. Which one of this mess of wires do you recommend me connecting to?
dave
ivanp
Posted: January 10, 2005 at 9:38 PM / IP Logged
I havent yet installed my alarm system in my truck but i recommend to get your hands on a multimeter and measure the voltage of some red wires which power 12V consistently when the engine is on and off (w/ and w/out the door open).  I am sorry I cant be some more help but i am still a newb and have only done this a couple of times.  If anyone else knows of a better way please post.  But as for right now, that is what i have always done it.
ivan
Hello
mobileworks
Copper - Posts: 136
Posted: January 11, 2005 at 10:40 PM / IP Logged
most keyless entry systems will require you to connect to the ignition wire and the constant wire..  so light GREEN/ purple and dk.blue/green
ground a piece of metal and door locks....
undash panel on that truck just pulls out using the handles and swind out to release the clips at the bottom.
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
