1991Toyota Corrola Wiring Diagram
J_keech13601
Member - Posts: 18
Posted: April 26, 2002 at 2:17 PM / IP Logged
I am looking for a wiring diagram for a 1991 Toyota Corrola
the12volt
Administrator - Posts: 3,959
Posted: April 26, 2002 at 2:32 PM / IP Logged
J_keech13601
Member - Posts: 18
Posted: October 06, 2002 at 10:43 PM / IP Logged
Is there any other wiring diagrams for this car? I have tried the 12 Volt diagram,one from Bulldog security and Chilton's repair manual and none look like the wiring I have. I have a Bulldog remote starter that works on the system, but can't get a Guardian alarm to work in it.
Platinum - Posts: 12,488
Posted: October 07, 2002 at 9:50 AM / IP Logged
|              12V|white or BLACK/ red  |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ orange        |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|blue/white          |-  |driver's kick panel         |
|     POWER UNLOCK|blue / YELLOW         |-  |driver's kick panel         |
| PARKING LIGHTS +|dk. green           |   |driver's kick panel         |
| PARKING LIGHTS -|lt.grn or lt.grn/blk|   |steering column             |
|       HEADLIGHTS|RED / white *2        |-  |steering column             |
|     DOOR TRIGGER|blk/wht or blk *1   |-  |2 pin plug at fusebox       |
|  TRUNK/HATCH PIN|RED / white *3        |-  |light or sw. in trunk       |
|         HOOD PIN|red                 |-  |anti-theft mod. or pin      |
|  FCTRY ALARM ARM|white or blue / YELLOW|-  |dr. kick or theft mod.      |
|FCTRY ALRM DISARM|wht/grn or blue/wht |-  |same                        |
|       TACHOMETER|black               |   |igniter or fusebox          |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN/ red           |-  |steering column             |
|           WIPERS|blue/black          |+  |steering column             |
|  LF WINDOW UP/DN|grn or rd,yel or grn|A  |driver's door switch        |
|  RF WINDOW UP/DN|GREEN/ red, blue/wht |A  |dr. door or kick panel      |
|  LR WINDOW UP/DN|RED / grn, blue/black |A  |dr. door or kick panel      |
|  RR WINDOW UP/DN|RED / black, yellow   |A  |dr. door or kick panel      |
Notes:
*1 Anti-theft module, 18 pin plug, pass. kick panel  *2 Also ground RED / green for cars with retractable headlights.  *3 Wagons' tailgate common with doors. Also at anti-theft module at pass. kick panel.
J_keech13601
Member - Posts: 18
Posted: October 07, 2002 at 10:25 AM / IP Logged
Jeff,
Thank you very much for the list. I will give it a shot.
Posted: October 07, 2002 at 10:43 AM / IP Logged
Toyota
Corolla
1988-1991
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ ORANGE
Ignition #2:
BLACK / YELLOW
Ignition  #3:
N/A
Accessory:
BLUE/RED
Brake  Light:
GREEN / WHITE (+)
SWITCH ON BRACKET ABOVE BRAKE PEDAL
Tach  Signal:
BLACK
AT IGNITER OR DIAGNOSTIC PLUG *
Parking Lights:
GREEN
(+) AT FUSE BOX
Headlights:
RED / WHITE
(-) AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
WHITE/ GREEN OR BLU/WHT
(-) DRIVER KICK PANEL
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Diagnostic Plug Located On Driver Strut Tower. BLACK Wire Marked (IG-). Please Note Some Models Are Carburated.
Toyota
Corolla
1988-1991
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
BLACK/ RED OR WHITE
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK/ ORANGE
Dome  Lights/Superv:
RED / WHITE OR BLUE
(-) PLUG AT FUSE BOX
OEM Horn:
GREEN/ RED (-)
STEERING COLUMN HARNESS OR AT RELAY
Power  Lock:
BLUE/WHITE
DRIVER'S KICK PANEL **
Power  Unlock:
BLUE / YELLOW
Trunk  Release:
N/A
Alarm  Input Wire:
RED / WHITE OR BLUE
Notes:
**  - Negative Pulse Door Lock
Here is another source information on the Corolla.
