need 1996 tahoe stereo wiring
tahoehtp
Member - Posts: 6
Posted: January 14, 2005 at 7:02 AM / IP Logged
Hello
Does anyone have the wiring color code for the factory amp for the rear door panel? I have put in the jvc headt unit and lost the rear door, and I heard there is amp for the rear door speaker, and for the future would like to remove that amp and rewire. any help appriciated.
mobileworks
Copper - Posts: 136
Posted: January 16, 2005 at 7:38 PM / IP Logged
make sure you power up the pink wire in the vehicle wiring harness....this should be like the fourth pin in the plug and is usually designated power antenna lead.
oh but the dr side colors should be yellow and brown and pass side should be dk.blue and lt. blue.
tahoehtp
Member - Posts: 6
Posted: January 16, 2005 at 7:49 PM / IP Logged
Thanks. I id figure out to day in the 23F weather, plugging the blue wire to the remote lead on the head unit speaker came back to life. I think for now I"m going to leave it this way til it's more warmer outside...
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
