2002 Jeep Wrangler Alarm/Remote Start Wiring
chiarlanza
Member - Posts: 30
Posted: January 17, 2005 at 6:04 PM / IP Logged
Hello:
I am about to install an alarm/ remote start into a 2002 Jeep Wragler
Does anyone have the propper wiring diagram?
Thanks in Advance..
Bob
mo12v
Posted: January 17, 2005 at 8:26 PM / IP Logged
Constant 12 voltsPINK/BLACK & REDIGNITION SWITCH HARNESS
Ignition 12 voltsBLUEIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightYELLOW (-)14 PIN GRAY CONN DRIVER'S KICK PANEL
Trunk Pin Switch
Parking LampBLACK / YELLOW (+)AT HEADLIGHT SWITCH
Power LockNOT OFFERED IN VEHICLE
Power UnlockNOT OFFERED IN VEHICLE
Accessories
Window UpNOT OFFERED IN VEHICLE
Window DownNOT OFFERED IN VEHICLE
Ign Key WarnL BLUE (-)IGNITION SWITCH HARNESS
Trunk Release
OEM HornRED / YELLOW (-)AT STEERING COLUMN
HeadlightsL GREEN (+)AT LIGHT SWITCH
OEM Alarm Arm
OEM Alarm Disarm
Remote Start
Tach SignalGRAY/WHITEAT COIL
Ignition #2BLACK/ ORANGEIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBLACK/ D GREENIGNITION SWITCH HARNESS
Neutral SafetyBROWN / L BLUE (-)BLACK 32 PIN CONN AT PCM
Brake LightWHITE/ TAN (+)AT SWITCH ABOVE BRAKE PEDEL
Reverse LightVIOLET (+)DRIVER'S KICK PANEL
Rear Window Defrost
 Immobilizer Bypass  (With Gray Key).
MO
