1996 Chryslers Intrepid Wire Diagram
aseraper
Posted: January 25, 2005 at 2:48 AM / IP Logged
Please help me, I need the 1996 Chryslers Intrepid Wire Diagram for install Prostart CT3300.  Thank you!!!
jandjav
Member - Posts: 13
Posted: February 05, 2005 at 12:30 AM / IP Logged
PRINTABLE VERSION
DODGE
MODEL YEAR(S)
INTREPID 1994 -1997
KEY T-HARNESS IMMOBILIZER
N/A CHR-3 N/A
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT PINK/BLACK and RED IGNITION SWITCH HARNESS
STARTERYELLOW/GOLD DOTS (+) IGNITION SWITCH HARNESS
STARTER 2N/A
IGNITION 1DARK BLUE/GOLD DOTS(+)IGNITION SWITCH HARNESS
IGNITION 2RED / WHT/GOLD DOTS (+)IGNITION SWITCH HARNESS
IGNITION 3RED / WHITE (+) 18ga. Needed only if air bag light turns on IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1BLACK/ ORANGE (+) IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2N/A
KEYSENSEN/A
PARKING LIGHTS ( - )NN
PARKING LIGHTS ( + )BLACK / YELLOW (+) IN DRIVERS KICK PANEL
POWER LOCKORANGE / WHITE @ WHITE Plug, BACK of FUSE PANEL (TYPE A)
POWER UNLOCKPINK/VIOLET @ WHITE Plug, BACK of FUSE PANEL (TYPE A)
DOOR TRIGGERTAN and TAN/RED (-) See NOTE * IN DRIVERS KICK PANEL 24408_INTREPID_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
DOMELIGHT SUPERVISIONTAN (-) See NOTE * IN DRIVERS KICK PANEL
TRUNK RELEASEBLACK/ WHITE (+) @ TRUNK RELEASE SWITCH
SLIDING POWER DOORN/A
HORNBLACK/ RED (-) @ RELAY in FUSE PANEL
TACHRED, WHITE or BLACK @ COIL PACK
WAIT TO START LIGHTN/A
BRAKEWHITE (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM LIGHT GREEN/ ORANGE (-) thin wire IN EITHER KICK PANEL
ANTI-THEFTN/A
EXTRA INFORMATION
NOTE * when connecting to an Alarm System use BOTH wires and DIODE ISOLATE, for DOMELIGHT SUPERVISION use the TAN (-) wire only.
LINK 1 LINK TEXT 1 LINK 2 LINK TEXT 2
