Request 1994 Toyota 4-runner alarm wiring diagram
chyneezb0y
Posted: October 26, 2002 at 8:36 PM / IP Logged
An alarm wiring diagram for 1994 Toyota 4-runner?
Platinum - Posts: 12,488
Posted: October 26, 2002 at 9:53 PM / IP Logged
|              12V|white - WHITE/ red   |+  |ignition harness            |
|          STARTER|black               |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|blk/yel or blk/red  |+  |ignition harness            |
|        ACCESSORY|blue/red            |+  |ignition harness            |
|       POWER LOCK|blue/white          |-  |door control relay *2       |
|     POWER UNLOCK|blue / YELLOW         |-  |door control relay *2       |
| PARKING LIGHTS +|green               |   |drivers kick panel *3       |
| PARKING LIGHTS -|RED / black           |   |steering column             |
|       HEADLIGHTS|RED / white           |-  |steering column             |
|     DOOR TRIGGER|BLACK/ white or black|-  |2 pin plug top fusebox      |
|  TRUNK/HATCH PIN|GREEN / WHITE         |-  |rear window relay *4        |
|       TACHOMETER|black               |   |check connector *1          |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
|     HORN TRIGGER|GREEN/ red           |-  |steering column             |
|           WIPERS|blue/black          |+  |steering column             |
|  LF WINDOW UP/DN|blu/grn - blu/yel   |A  |in drivers door             |
|  RF WINDOW UP/DN|RED / blk - RED / grn   |A  |in drivers door or dkp      |
|  LR WINDOW UP/DN|blu/blk - RED / blu   |A  |in drivers door or dkp      |
|  RR WINDOW UP/DN|RED / yel - RED / blu *5|A  |in drivers door or dkp      |
Notes:
*1 The diagnosis connector is located on the passenger inner fender near the fuse/relay box.    *2 Door control relay is located behind the driver's dash speaker.  *3 Can also be found at any illuminated switches, radio, or some cigarette lighters.  *4 The rear power window relay is in the left rear quarter panel, behind trim, near tail light. The trunk pin can also be found yellow/black in the drivers kick (rest at ground, diode Isolate from dash indicator).  *5 The rear tailgate window motor wires are red for up, and green for down.  Both wires can be found at the rear window relay. We advise that you use the trunk pin wire to disable your rear window module, so the rear window doesn't operate when the rear door is open.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
