Remote start wiring 95 Riviera
Falco19
Posted: February 14, 2005 at 11:31 AM / IP Logged
Namly the HVAC wire
boomer_106
Silver - Posts: 710
Posted: February 14, 2005 at 8:03 PM / IP Logged
Buick
Riviera
1995
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS*
Ignition  #1:
PINK
Ignition #2:
WHITE OR PINK/WHITE
IGNITION SWITCH HARNESS (ECM)
Ignition  #3:
PURPLE / WHITE
IGNITION SWITCH HARNESS (HEAT/AC)
Accessory:
ORANGE
Brake  Light:
WHITE
ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
IGN CONTROL MOD. - REAR OF ENGINE
Parking Lights:
BROWN (+) LAMP CONTROL
MODULE - DRIVER SIDE OF STEERING COLM
Headlights:
LIGHT BLUE
(+) AT SWITCH
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This Vehicle Is Equipped With GM's VATS Anti-Theft System; See Note #237.
Buick
Riviera
1995
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
OEM Alarm Disarm:
LIGHT GREEN
(-) DRIVER KICK PANEL
Dome  Lights/Superv:
DARK BLUE (-)
DRIVER KICK PANEL - HARNESS FROM DOOR
OEM Horn:
BLACK
(-) STEERING COLUMN HARNESS
Power  Lock:
LIGHT BLUE
DRIVER'S KICK PANEL**
Power  Unlock:
WHITE
Trunk  Release:
BLACK/ WHITE
(+) AT RELEASE BUTTON
Alarm  Input Wire:
DARK BLUE (-)
Notes:
** See Note #202 - Positive Pulse Door Lock Diagram.
Falco19
Posted: February 15, 2005 at 9:20 AM / IP Logged
thanks
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
