1991 Ford Escort Wiring, UK
birchy
Posted: February 21, 2005 at 10:26 AM / IP Logged
I have looked at the 1991 Escort in your database but it is not the colours i have. Is it because mine is a European car?
Any help is grateful cause i am tearing my hair out!!
thepencil
Gold - Posts: 1,526
Posted: February 23, 2005 at 11:03 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / ESCORT (UK) / 1991 / Remote Start
[PRINT THIS PAGE]
12volts
Starter BLACK/ blue      ignition harness
Second Starter
Ignition black      ignition harness
Second Ignition
Third Ignition
Accessory yellow      ignition harness
Second Accessory
Keysense
Power Lock yellow/brown    -   behind o/s kickwell speaker
Notes: If the vehicle has deadlocking use channel 2 via relay to give the 2nd pulse on the lock wire.
Power Unlock WHITE/ brown    -   behind o/s kickwell speaker
Lock Motor
Unlock Motor
Parking Lights+ wht/blk & grn/blk     at the steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger BROWN / red    -   wht 5 pin conn in fusebox
Dome Supervision
Trunk/Hatch Pin BROWN / red      at the bootlight
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer green      ignition coil
Wait to start
Brake Wire
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer Bypass Module: Not Available
DIRECTWIRE™ WIRING INFORMATION - FORD / ESCORT (UK) / 1991 / Security
[PRINT THIS PAGE]
12volts
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Dome Supervision
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
DIRECTWIRE™ WIRING INFORMATION - FORD / ESCORT (UK) / 1991 / Keyless Entry
[PRINT THIS PAGE]
12volts
Lock Motor
Unlock Motor
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Dome Supervision
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Be careful whose advice you buy, but be patient with those who supply it.1991 Ford Escort Wiring, UK -- posted image.
Thursday, October 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
