2002 Dakota Alarm/Remote Start Wiring
Two_Cold
Copper - Posts: 91
Posted: February 26, 2005 at 10:27 AM / IP Logged
Hi everyone.
Any one have a 2002 wiring diagram for a 2002 Dodge Dakota 4 door?
It would be much appreciated.
Installing a remote start & alarm.
boomer_106
Silver - Posts: 710
Posted: February 26, 2005 at 11:30 AM / IP Logged
Dodge
Dakota
2000-2002
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
DK. BLUE / YELLOW OR YELLOW
IGNITION SWITCH HARNESS *
Ignition #1:
DK. BLUE
Ignition #2:
GREEN/ RED
Ignition #3:
N/A
Accessory:
BLACK/ ORANGE & GREEN
Brake Light:
WHITE/ TAN
AT SWTICH ABOVE BRAKE PEDAL
Tach Signal:
BLACK/ GRAY
AT IGNITION COIL OR AT PCM
Parking Lights:
BLACK / YELLOW (+)
AT HEADLIGHT SWITCH
Headlights:
LT. GREEN/ ORANGE (-)
AT HEADLIGHT SWITCH
Diesel Glow Plug:
N/A
Clutch Bypass Wire:
Notes:
* If This Vehicle Has A Gray Ignition Key, Then It Is Equipped With A Transponder Immobilizer System. See Installation Note #144 - Bypassing Transponder Theft Systems.
Dodge
Dakota
2000-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
PINK/BLACK & RED / LT. BLUE
OEM Alarm Disarm:
LT.GREEN/ ORANGE
AT CENTRAL TIMER MODULE IN DRIVER'S KICK PANEL ****
Dome Lights /Superv:
TAN (DRIVER'S) & TAN/RED (OTHERS)
(-) AT CENTRAL TIMER MODULE IN DRIVER'S KICK PANEL
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power Lock:
WHITE/ GREEN
Power Unlock:
WHITE/ GREEN
Trunk Release:
N/A
Alarm Input Wire:
Notes:
*** See Installation Note #211. Single Wire Lock System, A Negative Trigger Through A 820 Ohm Resistor Will Lock Doors. A Negative Trigger Through A 330 Ohm Resistor Will Unlock Doors. **** Single Wire System, A Negative Trigger Through A 644 Ohm Resistor Will Arm And Lock The Doors. A Negative Trigger Through A 1565 Ohm Resistor Will Disarm The Alarm And A Second Pulse (Double) Will Unlock The Doors.
Two_Cold
Copper - Posts: 91
Posted: February 26, 2005 at 10:50 PM / IP Logged
Thank you.
Two_Cold
Copper - Posts: 91
Posted: February 26, 2005 at 11:16 PM / IP Logged
Thank you.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
