VSS Wire - 05 Frontier
forbidden
Platinum - Posts: 5,354
Posted: April 21, 2005 at 2:06 PM / IP Logged
Trying to keep ahead of a really busy day here. If someone knows the location and color of this wire, would you please forward it to me.
the12volt
Administrator - Posts: 3,959
Posted: April 21, 2005 at 2:17 PM / IP Logged
VSS Wire: LOCATION 4- 2ND ROW FROM TOP OF ECM 4TH POSITION TO RIGHT OF BOLT IN ECM
VSS Wire Color: GREEN/ BLACK
VSS Pulse: 2000
VSS Tach Wire: LOCATION 16- 2 PIN CONNECTOR AT DISTRIBUTOR
Tach Signal Wire Color: BLACK/ RED
Brake Switch Positive: RED / YELLOW
Brake Switch Negative: RED / GREEN
VSS Wire - 05 Frontier -- posted image. the12volt • Support the12volt.com
