2002 Acura TL Type S Remote Start/Alarm
monky
Posted: June 12, 2005 at 1:17 AM / IP Logged
Hi Guys,
Can I get the wiring diagram for a 2002 Acura TL Type S to install a Remote Start and Alarm. The existing entry is a bit messy and is missing the necessary wires for the remote start (like alternator sensing wire, or do i get that from the engine bay) Thanks.
jc
thepencil
Gold - Posts: 1,526
Posted: June 13, 2005 at 8:44 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - ACURA / TL / 2002 / Remote Start
12volts white   +   ignition harness
Starter BLACK/ white   +   ignition harness
Second Starter N/A
Ignition BLACK / YELLOW   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow   +   ignition harness
Second Accessory WHITE/ black   +   ignition harness
Keysense blue/white   -   ignition harness
Power Lock BLACK/ blue   -   passenger fuse box
Notes: Located in a blue or gray 22 pin connector in front of the passenger fuse box. Use the key switch in the passenger door to test.
Power Unlock orange   -   passenger fuse box
Lock Motor WHITE/ red   5wi 18 pin grn plug, driver fuse box
Unlock Motor yellow   5wi 18 pin grn plug, driver fuse box
Parking Lights+ RED / black   +   4 pin grn plug top of pass. fuse box
Parking Lights- RED / yellow   -   headlight switch
Hazards same as turn signals
Turn Signal(L) GREEN/ blue   +   steering column
Turn Signal(R) GREEN/ YELLOW   +   steering column
Reverse Light GREEN/ black   +   2 pin brn plug below pass. fuse box
Door Trigger BLACK/ white   -   4 pin grn plug top of pass. fuse box
Dome Supervision use door trigger
Trunk/Hatch Pin blue/green   -   18 pin gry plg left of dri. fuse box
Hood Pin yellow   -   lt. blue plug below pass. fuse box
Trunk/Hatch Release white or WHITE/ red   +   driver fuse box or pass. MUX module
Notes: The passenger MUX module is located behind the glove box.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock BLACK/ red to blue   -   driver door key cylinder in door
Tachometer blue   ac   tach test connector
Notes: The tach test connector is a 2 pin connector near the air intake on the driver side shock tower.
Wait to start N/A
Brake Wire WHITE/ black   +   brake pedal switch
Parking Brake GREEN/ red   -   lt. blue plug below pass. fuse box
Horn Trigger lt. GREEN/ blue   -   steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556HW
Alternate Part1 #: 556UW
Alternate Part2 #: 555H
Alternate Part3 #: 555U
Notes:
Be careful whose advice you buy, but be patient with those who supply it.2002 Acura TL Type S Remote Start/Alarm -- posted image.
