1992 VW Polo G40 wiring
rmas
Posted: June 19, 2005 at 5:05 PM / IP Logged
Hi, do you have any wiring diagrams for this car... (Vw Polo G40 1992)
thepencil
Gold - Posts: 1,526
Posted: June 20, 2005 at 9:54 AM / IP Logged
I don't have 92, but hopefully the information below might serve some used to you.
DIRECTWIRE™ WIRING INFORMATION - VOLKSWAGEN / POLO (UK) / 1996 / Remote Start
12volts
Starter RED / black      ignition harness
Second Starter
Ignition black      ignition harness
Notes: Fuel pump wire is RED / yellow, 6 pin conn. in the fusebox.
Second Ignition
Third Ignition
Accessory BLACK / YELLOW      ignition harness
Second Accessory BROWN / red      ignition harness
Keysense
Power Lock grey/red    +   either kick panel
Power Unlock grey/black    +   either kick panel
Lock Motor
Unlock Motor
Parking Lights+ blk/grn & blk/wht     blk 12 pin conn in fusebox
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger BROWN / white    -   blk conn left of fusebox
Dome Supervision
Trunk/Hatch Pin BROWN / red      under rear light ctrl unit
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer
Wait to start
Brake Wire BLACK/ red      brake pedal switch
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Modules: Not Available
DIRECTWIRE™ WIRING INFORMATION - VOLKSWAGEN / POLO (UK) / 1990 / Remote Start
12volts
Second Starter
Notes: Fuel pump wire is RED / yellow behind the n/s kick panel.
Second Ignition
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock
Power Unlock
Lock Motor
Unlock Motor
Parking Lights+ blk/grn & blk/wht     at the steering column
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger BROWN / white    -   driver door switch
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Disarm No Unlock
Tachometer
Wait to start
Brake Wire
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Be careful whose advice you buy, but be patient with those who supply it.1992 VW Polo G40 wiring -- posted image.
rmas
Posted: June 20, 2005 at 10:43 PM / IP Logged
Thank you for the information...
Thursday, October 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
