remote start for 2001 ford focus
walterdhauck
Member - Posts: 7
Posted: November 24, 2002 at 4:03 PM / IP Logged
I have a 2001 ford focus, 4 door, se, with keyless entry. I need the wiring diagram for the focus, and the wiring diagram for the keyless entry because the remote start uses the existing keyless remote.
walter hauck
Platinum - Posts: 12,488
Posted: November 24, 2002 at 4:41 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+  |ignition harness            |
|          STARTER|gray/black          |+  |ignition harness            |
|         IGNITION|GREEN/  YELLOW        |+  |ignition harness            |
|        ACCESSORY|yellow              |+  |ignition harness            |
|       POWER LOCK|BLACK/ red           |-  |drivers kick panel          |
|     POWER UNLOCK|BLACK / YELLOW        |-  |drivers kick panel          |
|       LOCK MOTOR|yellow/black        |   |drivers kick panel          |
|     UNLOCK MOTOR|WHITE/ black         |   |drivers kick panel          |
|    DISARM DEFEAT|WHITE/ black         |   |passengers kick panel       |
| PARKING LIGHTS +|ORANGE / black        |   |headlight switch            |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|grn/blu(L),grn/yel(H|+  |steering column *3          |
|     DOOR TRIGGER|BLACK/ blue          |-  |low in drivers kick panel   |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|BLACK/ white         |-  |trunk light                 |
|         HOOD PIN|BLACK / YELLOW *4     |-  |keyless module *1           |
|TRNK/HTCH RELEASE|BLACK / YELLOW        |-  |switch or keyless module *1 |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|BLACK/ green         |   |ignition coil               |
|      SPEED SENSE|WHITE/ green         |   |radio                       |
|       BRAKE WIRE|lt. GREEN/ red       |+  |brake switch *2             |
|     HORN TRIGGER|BLACK/ blue          |-  |steering column             |
|           WIPERS|WHITE/ green         |+  |steering column             |
|  LF WINDOW UP/DN|yellow - white      |A  |in drivers door at motor    |
|  RF WINDOW UP/DN|yel/pur - wht/pur   |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|yel/blu - wht/blu   |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|yellow - white      |A  |drivers switch or kick panel|
| SUN RF OPN/CLOSE|                    |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|ORANGE / black (thick)|+  |radio                       |
|     RADIO GROUND|blk/yel & blk/grn   |-  |radio                       |
|     RADIO SWITCH|YELLOW /GREEN        |+  |radio                       |
| RADIO ILLUMINATE|ORANGE / black (thin) |+  |radio                       |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|wht/blk - gry/blk   |   |radio                       |
|       RF SPEAKER|wht/red - gry/red   |   |radio                       |
|       LR SPEAKER|wht/pur - gry/wht   |   |radio                       |
|       RR SPEAKER|white - gray        |   |radio                       |
Notes:NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. *1 Keyless module is behind the glove box to the right. *2 To meter the brake wire, must turn ignition on. *3 Low beam at the headlight switch is GREEN/ red. *4 Only if equipped with factory alarm.
brmoser
Posted: November 24, 2002 at 4:42 PM / IP Logged
{p}{!-- ZoneLabs Popup Blocking Insertion --}Walter hauck,{/p}{p}Any luck with finding information?I have the same vehilce and am ready to install Audiovox APS685.  Any info om installation would help greatly!{/p}{p}Thanks, brmoser{SCRIPT}window.open=NS_ActualOpen;orig_onload = window.onload;orig_onunload = window.onunload;window.onload = noopen_load;window.onunload = noopen_unload;{/SCRIPT}{/p}
brmoser
Posted: November 24, 2002 at 4:47 PM / IP Logged
{p}Jeff,{/p}{p}Thanks, you helped both of us out!{/p}{p}Thanks again.{/p}{p}Brian{IMG src="forum_images/smiley1.gif" target="_blank"}{!-- ZoneLabs Popup Blocking Insertion --}{SCRIPT}window.open=NS_ActualOpen;orig_onload = window.onload;orig_onunload = window.onunload;window.onload = noopen_load;window.onunload = noopen_unload;{/SCRIPT}{/p}
Posted: November 24, 2002 at 4:55 PM / IP Logged
No problemo
walterdhauck
Member - Posts: 7
Posted: November 24, 2002 at 6:22 PM / IP Logged
how do I bypass the passive immobilizier and where is it located?remote start for 2001 ford focus -- posted image.
walter hauck
Posted: November 24, 2002 at 9:04 PM / IP Logged
PATS system is built ontot he side of the ignition cylinder. You will require a working PATS key and a bypass module in order to bypass the system.
walterdhauck
Member - Posts: 7
Posted: November 25, 2002 at 6:24 AM / IP Logged
remote start for 2001 ford focus -- posted image.On the keyless entry module I need to hook up to a negative trigger input from the 2nd or 3rd channel output thatprovides a momentary negative (-) signal. What wire would this be on the keyless entry module. A wir diagram would help alot.
walter hauck
autosound
Copper - Posts: 58
Posted: November 26, 2002 at 3:38 PM / IP Logged
The easiest way to disable the factory transponder is to remove the transponder from a working key by removing the red or black lug at the base of key or if the key has a light or remote cdl fitted it will be a glass piece with a coiled up wire in it ,,,,remove it and hot glue it to the inside of the steering cowling.....this is what we do on the UK spec vehicles if having remote start...good luck
Jt82
Member - Posts: 10
Posted: January 27, 2003 at 1:34 PM / IP Logged
When I installed a Remote Start in a 2001 Focus the vehicle sometimes started by remote and sometimes did not.  What could be the cause of this someone told me that the focus's run a 14 volt starter system
MECP Certified
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
