2005 f350 diesel
Mas952
Member - Posts: 7
Posted: July 25, 2005 at 8:51 PM / IP Logged
Hey I did a search an couldnt find wat i needed to do a remote start with keyless on a 2005 Ford f-350 diesel.  Is the 2004 the same? I found a diagram for that..thanks
Midwest Auto Salon
7604 147th Street
Apple Valley, MN 55124
952-997-7113
thepencil
Gold - Posts: 1,526
Posted: July 26, 2005 at 12:30 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES SUPER DUTY / 2005 / Remote Start
12volts yellow (30A), lt grn/pur (30A) +   ignition harness
Starter dk. green   +   ignition harness
Second Starter N/A
Ignition RED / lt. green   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW and RED / black   +   ignition harness
Second Accessory dk. blue/lt. green   +   ignition harness
Keysense BLACK/ pink   -   ignition harness
Power Lock pink / YELLOW (w/o keyless)   5wi driver kick, door harness
Notes: Vehicles with keyless entry, the lock wire is WHITE/ red (-), in the driver kick, door harness or also at the VSM, gray plug, pin 3.
The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Power Unlock pink/lt. green (w/o keyless)   5wi driver kick, door harness
Notes: Vehicles with keyless entry, the unlock wire is BLACK/ white (-), in the driver kick, door harness or also at the VSM, gray plug, pin 2.
Vehicles with keyless entry the VSM shuts down after the doors have been locked for a certain time period, to wake up the system refer to DirectFax document 1094.
Lock Motor pink/black   5wi driver kick or VSM, gray plug, pin 1
Notes: The VSM (Vehicle Security Module) is to the right of the accelerator pedal above the transmission hump below the radio. Not accessible from radio opening.
Unlock Motor RED / orange   5wi driver kick or VSM, gray plug, pin 7
Parking Lights+ brown   +   switch or VSM, green plug, pin 2
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt grn/wht (F), lt grn/org (R) +   turn signal switch
Turn Signal(R) wht/lt blu (F), org/lt blu (R) +   turn signal switch
Reverse Light BLACK/ pink   +   back of fuse box, black 8 pin plug
Door Trigger use dome supervision wire
Dome Supervision BLACK/ lt. blue   +   pass kick or cluster, blu plg, pin26
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer NOT RED / lt green or RED / yellow ac   any ignition coil or fuel injector
Notes: On diesel vehicles the tach wire is lt. GREEN / WHITE in a 5 wire harness held up with white tape behind the parking brake release.
Wait to start see DirectFax document 1091
Brake Wire lt. green   +   brake pedal switch
Parking Brake lt. GREEN/ red   -   switch or cluster, blue plug, pin 18
Horn Trigger dk. blue   -   switch or VSM, green plug, pin 6
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.2005 f350 diesel -- posted image.
whanner
Member - Posts: 8
Posted: August 09, 2005 at 7:45 AM / IP Logged
Hi All
does any one have the pinout info on the GEM for the VSS?
(hope thats the correct term) also has anyone made a remote start out of the 2nd or 3rd channel outputs of their alarm....seems like it would just take a few relays one being a time delay (i have a diesel) am i missing the boat with that ind of thinking? I have a 05' F250 Diesel.
if so i would like to know how you did it.
thanks for viewing.
thepencil
Gold - Posts: 1,526
Posted: August 09, 2005 at 11:22 AM / IP Logged
Kinda miss the boat in my opinion. Replace the whole unit all togeter. Get yourself an alarm and remote starter unit combination unit instead.
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES SUPER DUTY / 2005 / Accessory
Parking Lights- N/A
Headlight RED / yellow   +   switch or VSM, green plug, pin 7
Speed Sense gray/black      radio harness or ABS module, pin 21
Notes: The ABS module is in the driver side rear corner of the engine compartment.
Wipers dk. blue/orange   -   windshield wiper switch
LF Window up/dn WHITE/ black - tan/lt. blue   A   driver window switch in door
RF Window up/dn tan/lt. blue - WHITE/ yellow   A   driver kick, door harness
LR Window up/dn yellow/lt. blue - gray/orange   A   driver kick, door harness
RR Window up/dn RED / black - yellow/black   A   driver kick, door harness
Sun Roof open/close purple - dk. blue   A   sunroof motor or module
Sun Roof Limit/close white, black, or red   -   sunroof motor or module
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
No Type:
N/A
Part #: N/A
Notes:
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
