2000 suburban keyless entry
keith33
Posted: August 02, 2005 at 1:06 PM / IP Logged
looking for a wiring diagram for my 2000 suburban keyless entry system. It works when the inside of the vehicle is cool or at night and in the morning. but it does not respond to the remotes during the day light hours (when the vehicle is hot inside). any suggestions???
thepencil
Gold - Posts: 1,526
Posted: August 02, 2005 at 1:58 PM / IP Logged
Your guess is good as mine. These are the issue that drive most tech people crazy. Probably worth looking into an aftermarket keyless unit if the problem persist.
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / SUBURBAN / 2000 / Keyless Entry
12volts red   +   ignition harness
Starter yellow   +   ignition harness
Ignition pink   +   ignition harness
Power Lock lt. blue   +   pin A4, brown plug at BCM
Notes: The BCM (Body Control Module) is located behind the driver side of the dash. The plugs face towards the rear of the vehicle.
Power Unlock white   +   pin A3, brown plug at BCM
Lock Motor gray   5wi driver kick, door harness
Unlock Motor tan   5wi driver kick, door harness
Parking Lights+ brown   +   pin B6, lt. blue plug at BCM
Parking Lights- white   -   pin A5, lt. blue plug at BCM
Hazards same as turn signals
Turn Signal(L) lt. blue   +   steering column
Turn Signal(R) dk. blue   +   steering column
Door Trigger     -   BCM
Notes: Use tan for the driver door located in pin B4 of the purple plug, and the passenger doors are a blue/white in pin B11 of the lt. blue plug. Use both wires and diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock
Factory Alarm Disarm lt. green   -   pin B3, purple plug at BCM
Disarm No Unlock see factory alarm disarm
Horn Trigger black   -   pin A9, brown plug at BCM
Memory Seat 1 white   +   memory mod under dr seat
Memory Seat 2 purple   +   memory mod under dr seat
Memory Seat 3 N/A   +
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: 555T
Notes:
Door Lock Interface Required:
No Type:
N/A
Part #: N/A
Notes:
Combo Interface Required:
Yes Type:
Data Bus
Part #: 457GW
Notes: Can use the 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
Be careful whose advice you buy, but be patient with those who supply it.2000 suburban keyless entry -- posted image.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
