2005 Hummer H3 doorlocks?
tinterpa
Posted: September 26, 2005 at 9:16 AM / IP Logged
Vehicle is what i believe to be a 2005 hummer H3 door says 5/05 so anyways put a remote starter in it and cannot find door lock wires , all my tech sheets says they are  negative in either kick panel. Tried for hours no luck, now all my sheets that have wire colors are for a  2006 H3 not 2005  wondering if anyone knows something i dont, or if i can use a databus wire type system....
thanx in advance
Satkunas
Copper - Posts: 97
Posted: September 26, 2005 at 9:41 AM / IP Logged
My sources list Lt.blue and Dk.blue in the driver kick as well. Have you tried looking in the driver door boot?
As for datakits, the GM SL will do door locks, as well as a unified doorpin output, and parklight control.
BTW are you sure the H3 is a 2005? 2006 sounds more likely.
NowYaKnow
Gold - Posts: 1,217
Posted: September 26, 2005 at 7:42 PM / IP Logged
If it's an H3 then yes light blue and dark blue are the wires your looking for. You will find them in the kick in the harness that comes in from the drivers door. Not in the harness going down towards the door sill. If it's an H2 then you'll need/want to use an appropriate bypass.
Mike
