1974 vw beetle
edotoole
Posted: December 09, 2002 at 6:36 PM / IP Logged
Does any one have a full wiring diagram for a 1974 1601cc beetle
Platinum - Posts: 12,488
Posted: December 09, 2002 at 7:28 PM / IP Logged
|              12V|red                 |+  |rear of fusebox             |
|          STARTER|RED / black           |+  |ignition harness *1         |
|         IGNITION|black               |+  |rear of fusebox             |
| PARKING LIGHTS +|gray                |   |light switch, fusebox       |
|       HEADLIGHTS|WHITE/ black         |+  |light switch                |
|     DOOR TRIGGER|BROWN / white         |-  |either pin switch *2        |
|       TACHOMETER|green               |   |ignition coil               |
|       BRAKE WIRE|RED / black           |+  |brake switch                |
|     HORN TRIGGER|brown               |-  |at horn                     |
|           WIPERS|green or black      |+  |wiper switch or motor       |
Notes:
*1 found under hood near steering column.  *2 found under hood far left and right at rear of switch.
Friday, May 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
