95 Acura Integra GSR 2dr
zooom101
Posted: October 25, 2005 at 11:06 PM / IP Logged
This will be my first time installing an alarm in a car. I have a few questions. Are the doors on my car negative type? Are the wires that I'm supposed to splice into the ones that are under the dash on the drivers side near the fuse panel? Any help would be appreciated.
thepencil
Gold - Posts: 1,526
Posted: October 26, 2005 at 8:32 AM / IP Logged
Negative type
DIRECTWIRE™ WIRING INFORMATION - ACURA / INTEGRA / 1995 / Security
12volts white (50A)   +   ignition harness
Starter BLACK/ white   +   ignition harness
Ignition BLACK / YELLOW   +   ignition harness
Power Lock BLACK/ white   -   driver kick panel
Notes: In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way. The lock wires test only with the passenger lock and unlock switch.
Power Unlock BLACK/ red   -   driver kick panel
Lock Motor WHITE/ red   5wi lock control unit in driver door
Unlock Motor yellow/red   5wi lock control unit in driver door
Disarm Defeat no progressive unlock
Parking Lights+ RED / black   +   green plug above fusebox
Notes: Also a male blade terminal is available in fuse box.
Parking Lights- blue/red   -   factory alarm (if equipped)
Notes: The factory alarm is under the driver seat.
Hazards same as turn signal wires
Turn Signal(L) GREEN/ blue   +   steering column
Turn Signal(R) GREEN/ YELLOW   +   steering column
Door Trigger lt. GREEN/ red   -   driver kick panel
Notes: Looks like 14 awg wire but mostly insulation.
Dome Supervision use door trigger
Trunk/Hatch Pin green   -   blu 12 pin plug, top ctr of fuse box
Hood Pin yellow/red   -   driver kick panel
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Tachometer blue   ac   distributor
Notes: Also found in a 16 pin white or gray plug to the left of the fuse box.
Horn Trigger gray to blue/green   -   steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.95 Acura Integra GSR 2dr -- posted image.
Friday, January 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
