2002 Dodge Neon Wiring
hot_shot_guy123
Copper - Posts: 114
Posted: May 08, 2002 at 8:44 PM / IP Logged
I'm looking for a radio and alarm wiring diagram for this car, if anyone has it please post.
scss
Member - Posts: 25
Posted: May 08, 2002 at 8:59 PM / IP Logged
Year(s): 00-02
Make(s): Dodge/Chrysler
Model(s): Neon
As Of: 01/24/02
12 Volt (+)
12ga. Pink/Black at harness above driver’s kick panel (plastic tape), or 12ga. Red at ignition harness
Ignition 1
18ga. Blue/White at harness above driver’s kick panel (cloth tape), or 12ga. Blue at ignition harness
Ignition 2
Ignition 3
Accessory 1
12ga. BLACK/ Orange at ignition harness
Accessory 2
Starter
14ga. Yellow at driver’s kick panel (plastic tape)
Horn
18ga. BLACK/ Red (-) at same (plastic tape)
Tachometer
18ga. BLACK/ Gray at ignition coil or at PCM in engine compartment
Lights (+)
18ga. BLACK / YELLOW at driver’s kick panel (cloth tape)
Lights (-)
Brake Lights
18ga. WHITE/ Tan (+) at brake pedal switch
Door 1
18ga. Tan (-) (D.D.) at driver’s kick panel (cloth tape)
Door 2
18ga. Lt. Blue/Orange (-) at same (cloth tape)
Door 3
Door 4
Interior Lights
18ga. Yellow (-) at same (cloth tape) (can be used as door trigger, only it has a short delay)
Trunk/Hatch
18ga. Tan/Black (-) at same (for models with factory security)
Hood Pin
18ga. BROWN / Tan (-) at same (plastic tape) (for models with factory security)
Trunk Release
18ga. BROWN / Blue (-) at switch in center console, motor wire is 16ga. Lt. Green (reverse polarity) at driver’s kick panel or at R.K.E.
Lock (switch)
See arm/disarm below
Unlock (switch)
18ga. Lt. Green (-) at driver’s kick panel @ 400 - 500 ohm locks
Driver Unlock
Same wire (-) at same @ 0 ohm unlocks
Arm (key)
Same wire @ 1500 ohm arms and locks
Disarm (key)
Same wire @ 5000 ohms disarms and unlocks on second pulse
Arm Input
14ga. ORANGE / Black (M) at driver’s kick panel
Disarm Input 1
14ga. Pink/Black (M) at same
Disarm Input 2
14ga. Pink/Violet (M) at any passenger door harness
Jando
Security Specialist
If its a Ford Dont do it
